well it has been done before but the description was pretty imprecise, and no mention was made of binding, or aftermarket control arms, so what the hell i'll try it. i just won a 95 caprice 9c1 rear off ebay and will be picking it up on saturday.
what i plan on doing is getting the measurements first (since there's already a rear in the car, and i want to keep her driving as much as possible) and figure out the geometry. if things look close enough i'll try a loose bolt in.
any and all advice is requested.
i do know that the axle is wider, that just eliminates the wheel spacers i was going to use. and i know that the lug pattern is 5x5. worst case i get new axles with a 5x4.75 pattern. other than that i'll be making it up as i go.
i'll update this as it happens.
