BUILD THREAD 1987 Olds 442 Project Build
oldsofb
1,387
4,020
Maryland
I love the cold case radiator but would the stock olds 350 fan cool the engine enough or would the electric fans be a better option.
Even hopped up 455's just had the belt driven fan to cool them down back in the day.
The stock shroud with a 7 blade clutch fan should do the trick. Use a 180 degree thermostat and you should be fine. If for some reason it can't keep up, then you can start thinking about elect fans.
Hutch
oldsofb
1,387
4,020
Maryland
Catch up time.
The mock up on the Core support is done
I got a gift in the mail from PacificGbody in the form of their Balancer Pulley Adapter
Big thanks to them. The owner reached out to me on Insta and asked if I'd like to try and review it. It's a well made piece.
Hutch
Reactions: 4 users
oldsofb
1,387
4,020
Maryland
I had to make a brace for the top of the A/C Compressor Bracket.
I first use mechanics wire to make my shape and use it as a template.
I can refer to this as I hammer out my brace. The material is a piece of 1/2" pipe from the hardware store
I hammer the one side flat and then mark for length
Hammer the other side flat, bend and drill
Test fit and then mark the intake threads with tape to center the hole to be drilled
Drill and done
Round the edges and paint it black and you'd never know it was home made. (haven't done that yet since the intake isn't bolted down for good)
Hutch
  • Happy
  • Winner
Reactions: 13 users
69hurstolds
8,232
17,699
Hahaha! Hutch got a new sponsor!!!!! I'll let him tell you all about it in his starter vid. (y) Wait for it...
Headers hit, starter's back in. Break it down...oh oh oh oh...
Reactions: 6 users
Rktpwrd
Builder of Cool Shjt
4,180
23,982
Calgary, Alberta, Canada
Had very nearly the same problem with the PowerMaster clockable starter on mine, minus the clearancing of the header tubes. Lots of very finicky fussing to find just the right orientation for everything to fit and clear.
Reactions: 5 users
Oct 14, 2008
8,828
7,785
Melville,Saskatchewan
Yeah, I had to piece two mini starters together to get the right fit with my stainless headers. I wish Pacific G body would sell that bottom pulley adapter separate from their brackets. Pretty sure my guesstimate was slightly off and the bottom pulley isn't centered.
rfpowerdude
674
1,076
Palm Bay, Fla
