Hey guys. So I had kinda forgotten about the whole front hub/brake growling issue on the cutlass until last week going to the car show. It's quiet until 55mph+ and it's an audible noise and vibration too.
Sure enough, I had my master cylinder to prop valve lines reversed as the pic motorheadmike saved the day. I swapped the lines yesterday and bled the front brakes.
Came home today and started on rear pass side, bled with one man kit as I didn't have a helper and bleeding the rear drums are a PITA anyway!!! Got all corners bled, no air that i could see. Start car and pedal goes to floor!!!
The little button on the front of valve was tripped prior, and I've never been able to reset it either. I'm at a loss, I guess I'll try to bleed again tomorrow and see what happens. Alot of work to bleed, drop car down, nothing working and have to do it again.
As a reminder.....running new Blazer brakes on the front and stock drums on rear with all new parts....right at 800 miles on everything.
Any help is appreciated, thanks yall!
