MONTE CARLO battery drain issue
BlueJay84
8
Hello, I recently purchased a 1984 Monte Carlo SS and I'm having a battery drain issue. The original 305 was replaced with a 350. I've narrowed the issue down to the 2 wires connected to the alternator. One wire is a heavy gauge that goes to the battery, the other is a small gauge that goes into a wire harness but I'm not sure where it goes. When I disconnected them my test light went on then dimmed out within a few seconds. If I connect one wire at a time the test light won't come on. The test light only comes on when both wires are connected at the same time. Any help would be much appreciated
BlueJay84
8
pagrunt
9,267
15,671
Elderton, Pa
You should have three wires on it: one brown about 16AWG that goes into the dash harness & (assume it's a factory gauge car) going to the resistor wire to excite the alternator, two red 12 AWG wires with one in the same plug as the brown & one on the stud on the rear with both wires tied into the same main feed wire of the same color & gauge off the starter running into the dash harnes/fuse box. Make sure this is correct as it's the easiest check to do before tearing things apart.
565bbchevy
9,626
12,737
Michigan
This is what I'm working with
That looks like a 1 wire alternator, that black plug on the right is where a factory connector would plug into.
You should only need a large gauge charge wire going from the battery to the positive on the alternator.
You should also have a cover on the alternator terminal to protect it from accidently getting grounded.
BlueJay84
8
Thanks for the help, I removed the smaller gauge wire and that seems to have fixed the issue.
fleming442
Captain Tenneal
Dec 26, 2013
13,046
24,225
That's how I fix stuff- just unhook things until it works right without any troubleshooting. Get the 2 pin plug for the side and wire it correctly, chowderhead.
