MONTE CARLO battery drain issue
BlueJay84
8
Hello, I recently purchased a 1984 Monte Carlo SS and I'm having a battery drain issue. The original 305 was replaced with a 350. I've narrowed the issue down to the 2 wires connected to the alternator. One wire is a heavy gauge that goes to the battery, the other is a small gauge that goes into a wire harness but I'm not sure where it goes. When I disconnected them my test light went on then dimmed out within a few seconds. If I connect one wire at a time the test light won't come on. The test light only comes on when both wires are connected at the same time. Any help would be much appreciated
fleming442
Captain Tenneal
Dec 26, 2013
13,046
24,221
565bbchevy
9,621
12,728
Michigan
Do you know the part number for the correct plug? Also, do you have the correct wiring diagram?
The 1 wire alternator is self exciting so the added plug and wiring is not necessary to kick it on, that is why there is a plug there.
565bbchevy
9,621
12,728
Michigan
What happens if you install a plug anyway?
Most 1 wire alternators can be wired to use the plug if wired correctly, the main purpose of the 1 wire is ease of installation and to give it a clean look without the extra wires.
