Alk that we know its the og tank85GPLef41 said:sounds like a venting issue. Is it the original or replacement tank?
Venting won't affect the sending unit :idea:85GPLef41 said:sounds like a venting issue. Is it the original or replacement tank?
agreed. check the signal at the tank and at the dash.RITTER said:Its most likely just the ground wire for the sending unit or the main wire that goes from the sending unit to the gauge :idea:
