G-Body_Vet said:I've seen people go the CCC route with mild 350's,
People have used them on 455's too!
but wouldn't you be leaving a lot on the table with a 403, better heads and a cam?
No, you wouldn't be leaving anything on the table on a street build, All the computer does is control part throttle fuel metering and timing advance. To do this properly, all the ECM needs is a decent vacuum signal ( so no HUGE cams ) and to keep the compression ratio at a reasonable level because of the agressive timing curve. So as you can see, it doesn't have anything to do with cubic inches.
Maybe it's feasible for a driver but I'd go with one of the 800 cfm castings that have the adjustable part throttle (APT) screw to get the most out of it.
CCC carbs are 800 cfm castings and don't have the APT. The ECM meters the fuel, so it's just like having an APT though.
I'm not trying to start a pissing match with you
We're good! I didn't take any offense to what you said.
but if there's something miraculous I don't know about improving the CCC carb I'm all ears. I haven't bothered with one of these carbs in over ten years.
Nothing too miraculous about them IMO. It's just many don't realize how they work. I always hear people saying such things as 'the ECM is 'calibrated' for a 307' or 'my CCC engine only gets 10 mpg, so they suck' etc. Many only know what they've 'heard' about the CCC system, and it's usually wrong.
Now with all this said, to make a large CID/high performance engine run it's best on the CCC system, carb mods are usually recomendend, but not a must in all cases. I'd like to point out 2 things though; 1) even the stock engine can benefit from carb mods, and 2) and even non CCC Qjets need modding to perform there best in most applications.
