Wiper Motor question
-83MONTESS-
4,570
967
Bellevue, Ohio
I put my wiper motor back in, got all the wires hooked up right but when I hit the switch all I heard is a buzzing noise. I pulled the motor off of the mount but left the wires hooked up and tried it again and then it worked fine. But when I have it all hooked up, mounted and attached to the wiper arm it just buzzes or doesnt make noise at all :wtf: The motor worked fine before and appears to work fine now just not when its all hooked up does someone have a clue as to whats going on? I wiggled all the connections/wires around, ran a jumper ground wire to the frame just to eliminate a ground problem and even tried LIGHTLY tapping on it with a hammer but nothing. Oh and I also made sure the wiper arm itself wasnt stuck. Thanks to any input.
burgundy83
185
Saskatoon, Saskatchewan, Canada
Assuming it's the same one in my car (probably is), it's the relay that's sticking. If you pry the black plastic cover off (gently, the plastic is super brittle), it's under the green plastic cap. You've got to disassemble the board just enought to get that out, pry the green cover off and make sure there's no gunk on the contacts, there was a bunch of black sh*t all over mine. Just use fine sandpaper, straighten everything out, put it back together, and if it keeps buzzing, just wack it with your hand occasionally while turning your wipers on and off, that's what worked for me. I couldn't believe how touchy these things are.
-83MONTESS-
4,570
967
Bellevue, Ohio
Thanks for the info. Mine actually doesnt even have a plastic cover on it :shock:
Dragonist
424
16
Dallas, Tx
Maybe your wipers are stiff...IF that doesn't work check your grinds
pontiacgp
blank
Mar 31, 2006
29,270
20,397
Kitchener, Ontario
it has a overheat protector on it so that could be why you don't hear anything.....did you try moving the wiper arms when it was buzzing?
-83MONTESS-
4,570
967
Bellevue, Ohio
Yea I did that also. I just got done messing with it and it doesnt even buzz anymore.
-83MONTESS-
4,570
967
Bellevue, Ohio
pontiacgp said:
it sounds like the motor is toast, do you have another one to try?
No unfortunatley I dont but I dont understand how it could go bad when it worked perfect before and all I did was take it out to reach spedo cable (PO tucked it behind wiper motor).
Bonnewagon
Lost in the Labyrinth
10,571
14,316
Queens, NY
One of the little bolts has a ground strap- check that it is still under the bolt head.
