1985-1987 442 Gold Wheel Paint Codes
6,014
12,730
Did Colours buy up the Ditzler store (as we always called it growing up) on North Side off Perrysville by Perry HS? That has my go to store when I was living down that way.
No, that store has been closed for some time, maybe even before the Colours buyout. Miller's/Colours on Perry Hwy by Martorelli was always our PPG supplier when I was still doing auto body for a living. I still have an account with them and I still buy stuff from them every once in a while, but I not like I used to.
JeffinNashvilleTN
13
Hey 69hurstolds,
About your refurbished wheel, I'm assuming a plating company rechromed the wheel and you applied the gold paint?? Can you tell us what the cost of rechroming was and how did you go about applying the paint and striping? That really looks very well done.
Jeffrey
8,198
17,600
Hey 69hurstolds,
Jeffrey
That would have been nice, but no. It was just a good set of used rims. Just cleaned them up, taped off the center, painted the inserts, and put on new outer tape stripe.
It was a little time consuming to spruce up all 4 wheels, but worth it in the end.
JeffinNashvilleTN
13
Absolutely worth it. How did you get the striping tape on so......well, PERFECT!! You're hired!!:censored:
JeffinNashvilleTN
13
Hey 69hurstolds,
Jeffrey
Hey I found this . Haven't purchased one myself but hopefully in the near future. If anyone buys one please post up your pros and cons.
https://www.musclecarparts.cc/shop/...bkU0dAUG1YGIOY0sRf2DWaOgbK8ZZyaUaAiPkEALw_wcB
8,198
17,600
I'd be curious as to what that entails. I just used the 3/16" gold stripe roll from 3M. Close enough shade to work for what I needed it for. I just laid it down very carefully going slow and steady using my index finger to ride over the stripe to guide it into place and run along with the curve of the rim. It took a little practice to get the hang of it. It ain't perfect. But again, close enough for me.
And there's this to help keep sh*t straight:
https://www.amazon.com/dp/B07CBFC2MV/?tag=gbody-20
JeffinNashvilleTN
13
$30.00 stinking dollars for that?? Me thinks that 3M tape he has is probably the same thing you used.
