My first 78Delta88 was stolen, but in a little bit looking at restoring the coupe. It's a 403, but tons of sun rot so it's going to be a Mad Max interior.
Funny how that works, isn't it? Sometimes the "professional" grade product is a disappointment compared to something cheap or unconventional.Paint is funny stuff... One thing I found works ok, is Testors Model paint. On my TA the blizzard of 82 all it's front spoilers were torn off... Long story.
I had them replaced and professionally sprayed and looked like garbage. Got a can of Testors Gold and beautiful...
For these lights to look decent they must occupy a space on the trim panel that typically has a tab ahold of the inner sheet metal of the cabin. If it turns out to be absolutely necessary then I'll need to figure something out because I had to completely remove that bad boy. I like the way this looks and don't regret cutting up a perfectly good (although chalky) piece of trim. Now I'll make it black and pretty, and repeat the process for the other panel.
Thank you very much for commenting and trying to educate me. I didn't know that they were rare, but of course they were. No turning back now though and it'll play very well into the theme I'll be running with, which won't be revealed until later. Since you enjoy clever wordplay I think you'll be onboard with the moniker I've chosen, especially considering the theme and how it ties to Oldsmobile and the time period in general. The Recaro seats in the following photo are an intriguing clue as to the theme, and in time they'll replace the F Body seats in there now since those are killing my neck and lower back on long drives.Obviously I’m no stranger to modifications and wholly endorse them, i just wish you hadn’t done that to a rare set of factory black panels. They are rare as hens teeth being one year (78) only. I have a set of tan/camel panels that I would’ve let you have for the cost of shipping.
But I digress.
I think you’re going to find that you need those tab attachment points as they help hold the panels in place. Both of mine ended up breaking off, I plastic welded ones from a junkyard car onto mine just to keep them.
