What did you buy for your G-body today? [2024]
Some used parts.....
Nother 205/75r14. Same height as a 235/60r15. Hankook Kinergy. Hankook optimos are discontinued. I liked em in the wet, snow, and all around driving, kinergys are the newer model ig.
White wall and hubcaps will go back on until I can get enough money for 4 new 235s.
Reactions: Sweet_Johnny
Figured out a way to have the fans come on without burning up another input on the holley.
This relay is a dual output with three triggers. One for each output and the third signals both to turn on.
I will have the Holley control each fan with the trinary switch controlling both fans to come on as needed.
Some for the gbody, some for my daily.
Rockauto put a hurt'n on my bank account.
New booster and master to go with the already purchased prop valve for the elky. This should sort out the brakes now. Not much to replace after this.
My daily was having hard start issues. After digging around, found a bad alternater and a battery that wont take a charge anymore. Got the alt, tensioner, belt, and battery.
Most of this work wont happen until the weekend.
Brought home some 1/8" thick aluminum scrap from work so I can make a rear seat brace or two.
I searched for 5+ years for a center console, eventually I conceded that I wasnt gonna find one..
Actually bought a monte console to fit into the Cutlass but the shape never matched the Cutlass dash very well.
Found one on FB marketplace, factory black console. Asking $100, got it for $60 and sold $100 worth of my parts... So I made money buying the console.
Comparable console on ebay is significantly more.
Feel like I won the lotto.
Now I have a monte console to sell.
Gotta clean it up, get some fresh color on it, make a shifter surround, and get it in the car.
I FOUND ONE AT SALVAGE!!!!!!
But some of the dimensions aren't quite the same as what I've got. I have a lot to learn about these.. I originally just went in to check on an overflow bottle but asked about glass and was shocked when Ken (owner) told me $100 would walk it out the door. With how hard it is to find parts I decided I should take what was available. Thanks Ken!
Reactions: Rktpwrd and UC645
