Nother 205/75r14. Same height as a 235/60r15. Hankook Kinergy. Hankook optimos are discontinued. I liked em in the wet, snow, and all around driving, kinergys are the newer model ig.
White wall and hubcaps will go back on until I can get enough money for 4 new 235s.
Figured out a way to have the fans come on without burning up another input on the holley.
This relay is a dual output with three triggers. One for each output and the third signals both to turn on.
I will have the Holley control each fan with the trinary switch controlling both fans to come on as needed.
Simple & Robust Installation: Sealed MX-150 plug/harness with 2 ft control wires included. Reduces install time/costs. Optional output bus bar provides simple and compact connection to RT or CT fuse block product families.Optional Deutsch DT/AT Connector Output supports an industry standard for...
Snagged a Zr2 blazer rear sway bar from the yard. Needs a good cleaning and repaint and it looks like it will work just fine with the 8.8
I may have to go back for the 8.5 out of the Zr2 but space is going to be at a premium here soon.
New booster and master to go with the already purchased prop valve for the elky. This should sort out the brakes now. Not much to replace after this.
My daily was having hard start issues. After digging around, found a bad alternater and a battery that wont take a charge anymore. Got the alt, tensioner, belt, and battery.
I actually picked up a center console this weekend too. I need to clean it, paint it, make something at work for the shifter and make it look like it belongs in the car.
But some of the dimensions aren't quite the same as what I've got. I have a lot to learn about these.. I originally just went in to check on an overflow bottle but asked about glass and was shocked when Ken (owner) told me $100 would walk it out the door. With how hard it is to find parts I decided I should take what was available. Thanks Ken!
