CadiRat adventures
That should be a 800 cfm Qjet. The secondary pulloff can be removed, glad you found one. Cliff's pull offs are the best, he actually adds restriction so they don't release too quickly and cause a bog. Yeah probably the factory fuel pump. Glad the old girl is still floating along.
It’s actually a 750 cfm. I looked down the throat and it didn’t have the two little bumps the 800’s have. I had two that I sold for my brother never figured on having something to put them on. But I got all the parts after some searching! Thank you though!!
Good Lord, they didn't think a 500 ci engine could use more cfm? Crazy, exactly why they are malaise era cars.
True, but the intake is a major strangulation factor for power. As I read it is an up flow intake to make the carb and air cleaner fit under the hood. Meaning after the carb it goes down then up to get into the heads. That’s per a Cadillac performance site and parts sales. If you go back and look at the picture of the engine I posted, you can literally see how it was that way. 😓Cost of the aluminum performance intake is not cheap!
I had a 70 Sedan DeVille in senior year, 500 cubes. Even back then performance parts were impossible, and if you did find something it was beyond touch of the typical high school student.
The one I got from GK Chevy for $250, had a hitch to tow a boat. The car was full of Florida tri-fold brochures of yacht clubs and boat launches.
As big as it was it was 10 mpg City or Highway didn't really matter. Had it above 100 but not for long. About 90 mph the front end shook so bad, that was scary enough.
Got more work done on it Saturday. Cleaned and ground out the areas around the front and rear windows prepped with some rust-oleum paint so I can lay down the urethane window sealer. Should probably pull the front one but lack the help to pull and reset. So cheap and duty it will be! Also got some of the floor patched. Welding to rust is so fun!😵‍💫welds look ugly but as long as they hold, I’m happy
So it’s getting almost time to put it away for the winter. Probably next weekend after some more metal work on the floor and trunk. Definitely had plenty of options for the mice to come and go! And fixed the windshield leaks ,rear window leaks and adjusted the driver’s side rear passenger window. For final at this point I fiberglassed rust holes from the vinyl and chrome roof trim. With the chrome long gone I ground off the tabs, waterproofed with undercoating and fo-vinyled with flat black rust-oleum and a paint roller. As a ratrod it’s just right
just ran through the build, gotta love these loveless cars! ex-girlfriends parents had a '76 just like it, but in white over red. that car was only 9 or 10 years old back then, but they were known rust issues back then, something to do with low quality steel and poor quality primer. he'd had it painted a couple times, but the rust kept coming back...
just painting the roof makes a huge difference! keep it up, love to see thes barges make it back to the road!
Thank you! Being a New England car it was rust proofed and sound deadening. Though salt and water coming in the front and rear windows due to the vinyl roof rust rotted out the floors and trunk. It’s basically a 2-3 year car at best. Motor/transmission runs great so it will go in a ratrod. Scary is it’s almost all original.
Front passenger side 🙄
Trunk to be patched 😵‍💫
stereo mouse nests!🤣
No no no... Stitch some license plates together, paint them black and call it good. Cover with some old carpet from the alley next to the dumpster... Brings back memories!
Actually ; how bad is the damage on the roof under the vinyl top?
