That should be a 800 cfm Qjet. The secondary pulloff can be removed, glad you found one. Cliff's pull offs are the best, he actually adds restriction so they don't release too quickly and cause a bog. Yeah probably the factory fuel pump. Glad the old girl is still floating along.
It’s actually a 750 cfm. I looked down the throat and it didn’t have the two little bumps the 800’s have. I had two that I sold for my brother never figured on having something to put them on. But I got all the parts after some searching! Thank you though!!
True, but the intake is a major strangulation factor for power. As I read it is an up flow intake to make the carb and air cleaner fit under the hood. Meaning after the carb it goes down then up to get into the heads. That’s per a Cadillac performance site and parts sales. If you go back and look at the picture of the engine I posted, you can literally see how it was that way. 😓Cost of the aluminum performance intake is not cheap!
I had a 70 Sedan DeVille in senior year, 500 cubes. Even back then performance parts were impossible, and if you did find something it was beyond touch of the typical high school student.
The one I got from GK Chevy for $250, had a hitch to tow a boat. The car was full of Florida tri-fold brochures of yacht clubs and boat launches.
As big as it was it was 10 mpg City or Highway didn't really matter. Had it above 100 but not for long. About 90 mph the front end shook so bad, that was scary enough.
Got more work done on it Saturday. Cleaned and ground out the areas around the front and rear windows prepped with some rust-oleum paint so I can lay down the urethane window sealer. Should probably pull the front one but lack the help to pull and reset. So cheap and duty it will be! Also got some of the floor patched. Welding to rust is so fun!😵💫welds look ugly but as long as they hold, I’m happy
Windows as sealed. Hopefully no more leaks and they’ll stay in place 🙄. The chrome is long gone so I’ll clean up the window edges and call it good. May give the roof a quick scuff and spray bomb black but might be to fancy for that!
