ok so i see people with a body 12 bolts on there g bodys and i see theres aftermarket upper control arms that make it a bolt on so does that mean with these upper control arms there is no other mods that need to be done to fit these in a g body
The 64-72 A Body car rear ends will be the best ones to use....Staw away from the Olds 12 bolts though because they aren't as strong as the chevy, pontiac rear ends.....The 12 bolts from wider cars aren't worth the hassle if you ask me....I scored a 12 bolt out of a '69 Chevelle and used these from UMIPerformance and they made the deal a true bolt in....PontiacGP did a 10 bolt swap last year and he used the 64-67 rear and had some issues, I'm sure he'll pipe up. Here's the link: http://www.umiperformance.com/catalog/i ... ucts_id=77 oh yeah, your stock driveshaft will work, you just need a different rear U-Joint is all....
I bought the kit with the uppers and lowers...I've been told that you can use the existing lower arms , but I would try and get the ones from the donar car of available......I'm running 15x8 wheels with 4.5 backspacing, prior to that I hade 15x10 with 6.5 backspacing..........magoo_oner said:JBreu did you use the upper and lower control arms or just the upper and do i have to use both and what wheel backspacing is needed
