17.8 calculated MPG on last tank...Meh
Turbolq4
1,732
4,207
Nampa Idaho
My DD is a Hondork Accord that gets right around 30. '96 f250 'stroke does 15-18. '81 granny Malibu, LS swapped with large hairdryer gets 20s iffin I drive it nice like, gets low single digits if I beat on it. Ol ladies' Highlander gets 20.
New efficient engines are great!
8,831
7,790
I got 21 Imperial mpg which is identical. That was in my 70 Cutlass, Olds 260, non lock up TH350 with 2.78 gears and tall 215/7514 tires. Same combo with a 2004R/3.42 gears and shorter 235/60R14 tires 26 imperial mpg. Hoping for 30 imperial mpg with the 215/75R14 tires and a serpentine setup.
DRIVEN
8,087
14,570
*CENSORED*
305/200-4r/3.42s gets me 20 pretty consistently on the freeway. Occasionally 21. I don't even track it from tank to tank, just long trips.
8,831
7,790
Driven I am only 1 mpg ahead with less power. Hopefully I won't loose mpg putting back on the headers and dual exhaust, it made a huge power difference, so I will risk it.
8,831
7,790
It is not just the new engines, everything from the 6, 8 or 10 speed trans, which always keeps the motor at the most efficient rpm, also the diffs as well are designed for low friction and has thinner synthetic fluid factory. Heck, I gained 5 mpg going from a 2010 Dodge Challenger 3.5/5 spd to a 2017 Dodge Challenger GT AWD 3.6/8 spd. The AWD adds a 400 pound weight penalty and it is still a good 1/2 second faster in the 1/4 mile.
PBGBodyFan
788
1,221
Wisconsin
Finally checked mpg on my wagon, felt like it was poor and it sure is, 12.7 mpg on this the first full tank of gas I've used. Car starts/runs pretty well and smooth, it's been about 20 years since I had a 3.8 2bbl but feels maybe more sluggish than it should under acceleration. Bone stock 3.8 with 200-C, lockup isn't working so that might account for a couple mpg, 2.73's.
Huen79H/O
Jun 5, 2018
74
161
33
1979 hurst olds 350 olds/350 turbo no lock up stock rear diff.
Drive it 60 miles a day gets 16mpg with ac on the same as my 03 Yukon
