Transfer slots are now square it was my fast idle screw adjustment that apparent controlled that
Like I said, leave it around 40 and run the full 16 degrees of vacuum advance. I am around 48 degrees total with my 9 to 1 Olds 350 and may add a couple more on my Mallory breakerless either by bumping the base timing 2 degrees or adding another couple degrees of vacuum advance or both. I had 22 base, 14 mechanical and a 30 degree vacuum can. No pinging but had bucking at low speeds. Switching to a 20 degree can, fixed it. I did notice lazier part throttle.Since I have to have such high initial timing would it be worth my while to just lock out the mechanical advance and leave the vacuum advance alone?
