I compared the stock style timing set and another stock balancer. I am sure it has to be in the right position. So it is actually much more normal sounding, no signs of life yesterday. The Powermaster mini starter has a lower pitch than the other mini but not stock either. It sounds mostly normal, no weird cranking like with the timing chain skipped at 475,000 km on an ds 307. I could tell I had the distributor in 180 out, popping out the exhaust. Went 180 the other to line up with #1 on the cap. It popped out the carb almost instantly. I cranked it to the firewall, cranked the distributor to the firewall, little better sounding, enough for tonight. I will go back one tooth and try again this weekend.
