Well I have the motor and trans out and into 88 CSC. I added the lock up solenoid wiring from the kit for the 2004R. I switched speedo cables and added the cruise transducer. I need to rebuild the washer pump, wire in the cruise and lock up switches, add the 6AL box etc. I made up the 7mm Summit retro ignition wires, they will look right at home. I put a fast curve in the Mallory Breakerless as well. I have the Olds 350 pulled down to a short block, tucked away the Performer can with lifters in order. I added a fresh rubber rear main and started cleaning gasket surfaces. I am adding a 1" open spacer under the Qjet on the Performer manifold. I will do some grinding to match up better between the spacer and manifold. I am going to clean up and plan on degreeing the custom 214/214 .472/.472 on a 110 LSA from Mark Remell, just waiting on it to get here. The fresh 2.07/1.56 #6 heads just need a quick clean up, then .028" head gaskets for 9 to 1. Dregreasing and scraping gasket surfaces. I am making this motor look stock with obvious and not so obvious add on's. Stay tuned.
