Nice to see you here, Mark! Some serious Olds advice is needed 'round here.Hello,
I am new here. I will post my info in the new user section but happened to come across this thread.
I offer Olds engine building and dyno services. I'm in Central Florida so I'm not that far from you I believe.
I agree with most of what's been written to this point with a few exceptions.
When using Edelbrock heads you would still use a small block intake, not a big block one. Also without good heads your target of 425hp will be difficult to achieve so put your time and money into the heads. And your '71 doesn't necessarily put out 310hp in stock trim so you'll need to spend a few bucks to get to your goal, sorry.
In addition I hope to be offering a stroker crank kit for all Small Block Olds from '64-'90. Let me know if I can be of any help. I'm an Olds owner as well and try to contribute to the Olds community whenever possible.
Thanks!!
It's wrong because building an engine with a goal of a certain power level is a complete package. Olds are not Chevies, and you need someone that knows them. You'll come up short ordering random parts off the internet if you don't know how it will come together in the end.Again, great news! Wish you had you been around 11 years ago as I really wanted to stay small block but new I would need to stroke a 350 to get where I am at with a mellow big block.
But, with these stroker kits, we are now talking about big block cubes here, folks, not a 350. Can someone tell me what I said below that is not true or to be disliked "about a 350"? I mean, if I'm lying to folks, I need to know it . . .
I highly doubt an aluminum headed big block is lighter than a small with iron heads.
Personally, unless you're on a budget or restoring it to concourse factory, I see no reason to not get aluminium heads. Irons are limited on lift, need hardened seats, weigh more, and have the exhaust crossover ports.
