1978 Malibu Barn Find
Small updates. Interior back together, some body panels hung, made a e-fan/rad mount combo, some plumbing done.
I have 3 different hoses and 1 universal kit to try and make one that tucks tight to the radiator to allow the intake to come on the passenger side.
Ran the ozone generator I got from Amazon to help eliminate any remaining mouse smell. I will be running this quite a few times to try and get it completely smell free.
Got around to installing the new Right Stuff brake lines and all went well except for the front most line on the master.
I used a 2000 blazer right hand drive master for this as well since I am doing blazer fronts and keeping the drums for now until I get enough extra $ tucked away for the 9".
I'm curious..... Why the specific use of a "2000 blazer right hand drive master" cylinder?
This master is threaded on the same side as the original unit to allow the stock pipes to thread in. Plus I wanted the screw on cap vs the clip in for easier brake bleeding since I have a tool I made back when I was in the shop for putting compressed air into the master reservoir to bleed the brakes.
Should be a direct replacement if your hoses are correct. looking at the one I have and their online pictures, which may or may not be actual representative product, mine is missing a twist to make the attachment in the right spot.
Reactions: scoti
Is that fan shroud/radiator mount all one piece? It looks really cool!
