Ok, so over the weekend i drove the malibu and was having some trouble starting the car after a little test drive, it sounded like it didnt want to turn over, like no power, there was $40.00 of gas so i knew that wasent the issue :wink: , everytime i would turn the key and crank my motor i would look at my volt gauge, it would be at 12-14 volts, then with the crank it will drop all the way to 2volts..
This dayum 70-85-90 stock volt alternators...
If you think about it im running Banging System, Lights, Electric fans, etc etc...on the stock alternator...so i went out to the junk yard and with all the help i read here on the forum i found a CS130 Alternator off a 1992 Chevy Pick-up Truck 5.7L, i was looking for a CS144 but no luck, I have heard nothing but good thing about both alternators just your preference...Took to autozone and PASSED twice
They only thing know is i need to find a pigtail alternator connector that will plug and play from a SI alt to a CS alt..ive done my research and found out that i need a connector with a resistor since the malibu had a Alt/Batt light when i had the horizantal stock gauge cluster...if i had it stock and connected i would need the connector with the resistor becuase the red light would give me the ohms that i would of needed...its very confusing, but real easy,just some good reading and u can figure it all out...plus theres some topics here on the forum...Im sure this alternator will do its job.
