I'd look for a 153 tooth flywheel for 1 piece rear main and a 10.5" clutch set with 10 spline disc.
Okay the flywheel can be had off ebay relatively cheap. What pressure plate needs to be used or are they all universal? I see the full package on RockAuto is reasonably priced. Can I buy that whole package and get a flywheel and be done with it?
I got that measurement for you. The shifter hole measures squarely at 4 3/8 inches, rounded on the corners. Coming off the driver's side seat mounting stud, go towards the tunnel 4 inches. From that spot measure toward the front of the car 8 3/4 inches. This location is where the driver's side back corner of the shifter hole is located. Again, that shifter hole measures 4 3/8 inches square. Hope this helps.on a completely unrelated, but interesting (to me) tangent, would you measure from the front seat stud to the factory cut out? I want to compare that to my car I just put a hybrid T5 in. I think I am pretty close, but I have nothing local to verify it against. Id like to go back into the car with the short center console if possible.
