Mando, both blend doors are driven by vacuum. If you look under the dash, you'll see a vacuum servo connected to each blend door. I had the same problem with the air only blowing thru the top and bottom vents, not thru the center dash vents.
I ended up replacing the control unit with one from a junked car. It seemed to do the trick.
It definitely sounds like a vacuum problem. Make sure the vacuum hoses are good, and where they connect together in a plug. I think the small diaphragm pod goes bad. They are not available new as far as I know, or else I'd purchase one.
Check the vacuum feed hoses coming and going. You can also check the blend doors by using a vacuum pump/ brake bleeder connected to the servo. Make sure the doors aren't hanging up, etc.
