The Ford and Chevy bolt patterns are different. The GM T5 case uses the same car transmission bellhousing bolt pattern that dates back to the 1930s. The Ford pattern might be called a Toploader?
In this photo, the Ford pattern 'tall/narrow/odd-man-left' is the one on the far left. The rest are GM, with the 'short/wide/odd-man-right four-bolt pattern'. The amusing detail is that the 'Ford' T5 is in fact from an Astro van, and used GM input and output spline patterns, rather than Ford 1"x10 spline input and 31 spline output. I found two of these over the years - 4.3L V6 backed by a T5 - and they have a cool bellhousing with the SBC block pattern and the Ford trans case bolt pattern, plus a cast-in arm for a hydraulic clutch slave cylinder like the later S10 bellhousing. I tried to get a transmission company to reproduce these years ago.
The Astro T5 has a 3.50 1st gear similar to that of a Saginaw, plus a 0.73 5th gear. The second one from the left is a World Class unit from an 89 Camaro. See how the cluster gear bearing cap has a ring around the edge? That's an easy way to tell. It's hard to see, but the Astro/Ford trans on the far left is also a WC. The Astro/S-10 input spline is 1"x14 spline. You can still get one of these from RockAuto if you search under Astro van. The S10 used a small <10" disc, while the Astro used an 11" disc. All would be fabulous if the S10 handled more than 300 ft-lbs of torque, but the design dates back to the Vega era when compact and light weight were the priorities.
The Mustang 'Z' was the final iteration that is till for sale today aftermarket.The Mustang tailhousing moves the shifter forward about 1-1/2" from the Camaro location, and I played around with a Mustang tailhousing and top cover/shift linkage, but never actually assembled such a Frankentrans. The GM tailshaft appears to stick out too far for the Ford yoke seal to work properly. I wanted to build a Camaro trans that sat vertically, and as Mike points, out, Mustang tailhousings are set up to sit vertically.
