i have no idea. ive only had the car going on 2 years and the previous owner did not know.how many miles on the engine?
it does not pop while in park. i havent tried in neutral.Does it pop through the carb when you rev the engine in park or neutral?
i added half a can of seafoam to the carb while at high rpms. shut the engine off for 10 minutes then turned it back on and reved the engine up again until smoke stopped. i can now floor it even more before carb starts popping. it got better. i'll run another compression test in a bit. waiting for car too cool down so i dont burn myself up trying to get the #7 plug out lol.after performing a compression test, and finding low compression. the next step in diagnosing your concern is to perform a cylinder leak down test to determine where the compression is going.
popping back through the carb usually indicates valve train issues, burned valves, sticky valve stems or lifters. while flat cam would give low compression, it would not cause popping back.
mmo or gm crank case cleaner may clean up the rings and give better compression, it would not address the popping back. it may help with sticking lifters depending on where the lifters are sticking.
adding zinc at this point would be a waste of money.
fellas, this car is a hoopty put together with junkyard parts. im not afraid to try some weird stuff to it, long as im not throwing crazy money at it. thanks.
