the cars done but it cranks and dies we changed the intake and check everything same issue
Where were the pictures of the GN Fuel Tank install with the High Pressure fuel pump?
What is your Fuel Pressure?
whats the VATS and no a/c for nowIt's the VATS, and the A/C isn't hooked up.
dissconnected the fuel relay and poked the fuel valve and gas does squirt out im thinking the pick a part people sold us a bad timing engine so we gonna take it out and play doctor
if it was the VATS the car shouldnt crank corrext or will it crank and them cut off ?whats the VATS and no a/c for now
i called it a night this cars been a tough one since the first engine and paint job to the interior and now the new engine ima take the computer back in the morning and post new info by tommorowWhat Fuel pump are you using and what is the fuel pressure? You need 30 psi or the car won't start. just "squirtting out" doesn't mean anything.
You put a good fuel pump in it to support a FI 6.0L, right?
50 psi fuel pressureWhere were the pictures of the GN Fuel Tank install with the High Pressure fuel pump?
Post #6 😗my boy who has a monte carlo ss ls swap thats who did all his work and they are fast and dependable. ive seen theyre work and im impressed the shops in spring tx
