Oh I just did the pry bar trick I was just saying that for the fact that the crank bolt was bad. Without the spacer u can thread it farther and it holds. Just need a longer bolt.anakputa said:turn over by the flywheel and with a screwdriver on the ring gear unless you have a tool to turn the flywheel by the ring gear. If it does want to budge fill the sparkplug holes with wd40 and let it soak, the rings might be frozen..
