1987 Chevy El Camino/SBC 355 Build (2nd Rebuild!!)
Re: SBC 355 Build (UPDATED WITH PICTURES 6-8-11)
nice work so far.. Is this your first build? if so, how are getting help?
I love this thread...Your doing a good job..I can't wait til it's up and running 🙂 Any plans for the dyno or no???
Thank You Guys!
Math <---- Yes This Is My First Build! My Fiancee's Dad Is Helping Me During The Build With Any Questions I Have. Am Also Using David Vizard's: How To Rebuild Your Small Block Chevy Book Along With Some GM Shop Manuals For Torque Specs.
JBreu <---- If I Could Afford Dyno Time I Def Would Run It On The Dyno, But For Now I Am Just Going To Get It Road Worthy Once Again And Have Some Fun With It! I Hope To Have It On The Road By The End Of July!
More Pics To Come In The Coming Days! Will Keep You Guys Posted!
Hey Everyone Got Another Update For You! Installed My Lifters, Pushrods and Rocker Arms Loosely Installed! Will Be Buttoning Up The 355 This Week! Enjoy!
Rockers, Pushrods and Lifters Installed
More Pictures Of The Progress To Come In The Coming Days! Enjoy!
Re: SBC 355 Build (UPDATED WITH PICTURES 6-12-11)
Looking good!!! I bet you want that thing running like yesterday by now.. Are those pushrod chromemoly or hardened? otherwise the guide plates will eat them right up. Just checking wouldnt want you to have problems later.
chevy2480 <---- They Are Hardened Pushrods Made For Guildplates, Thanks For Your Concern, Its Been A Long 1.3 Years So Yeah Im Eager To Get Motor Up And Running, But Also Am Taking My Time To Do It Right, But Ill Be Smiling For A Week When I Finally Do Fire It Up!
Are those ARP screw in studs? If they are DO NOT use those standard rocker nuts you have. They specifically state not to use the interference style not on their studs, they will back off. Ask me how I know 😳
Just went through and read all your thread here. I see they are comp. I would write them or give them a ring before you tighten everything down. I trashed my ARP studs using the same interference nuts you have. The rockers kept backing off and could not figure out why, I did some reading and found out the nuts were the reason. Do you know your deck height or piston to valve clearance, head gasket thickness? I am thinking 64cc heads with 2 valve relief pistons would net you over 10:1. Anyhow, nice looking set up. Looks like a stout build. Goodluck!
Chris.O <--- I Have Done The Research I Should Be Right Around 9.7:1 or a little higher, My Heads Are Not Exactly 64cc As Most GM Cast Heads Are Not Exactly What The Say They Are Without Proper Machining. Ill Be Happy If I Can Obtain A 400Hp!
