1987 cutlass Tarnished Betty
Looks like a Cutlass pick up truck now.
20170527_094226-jpg.67071
So I got the rear deck separated from my donor top as well as from my car. I have no idea what to do now. Do I use my existing trunk hinges which are a little rusty or remove them and use the ones attached to the donor rear deck? Has anyone done this before?
y
Try to take it apart at the spot welds. Do you have a spot weld cutter? Try to take it apart and put it together the way it was built new for the best repair and use the best stuff you have.
I bought one today but have no idea how to get it apart attached to the wheel wells. Can't get the right angle.
In that case it might not be the best approach. I haven't replaced that particular panel on these cars and mine is in storage so I'm not much help. Plan, plan, plan and then execute, and you'll be ok. Would a 90° drill attachment help?
