Time for your bath !
Looking alright after the metallic dust is off!
The 350 doesn't have the thermometer where it's supposed to be? Can I buy it off rockauto, do you have the correct part number for me and if an adapter is needed to thread it in?
I have this cluster, I need the oil pressure sender and the coolant thermometer to make this all work, can you please provide me with the correct part numbers because rockauto lists a lot of different parts and say they all fit, but I'm not so sure...
There is some clearance issue with this carb and air cleaner, it rubs up against the inside of the hood, I really can't think of a way to lower the air cleaner without interfering with the distributor, so maybe I need just a smaller circumference air cleaner?
