nothing new here, the doors are still waiting for attention, however I finished the brakes except for the firewall parking brake cable which I had bought but received an incorrect one, for an S-10 for some reason, so I'm still waiting for it.
I installed the shock absorbers in the front and back and the car is now relatively drivable again.
I hear some clunking in the rear end, definately it's the suspension links which are very worn rubber bushes, I imagine there is an easy solution just to buy the arms with bushings and bolts to replace the whole unit, I'm almost certain I'll have to cut the whole thing out..
I need wheel spacers in the back, the tires rub the frame a little bit when the suspension is compressed, the wheels would also look much better about 1/2 inch further out...
I'm looking for a simple HEI distributor because I want to get rid of the multi spark capacitive bull sh*t, it's giving me trouble when I drive for a long time the unit shuts the car off and won't restart until I completely switch the ignition off for about 10 seconds and then restarts, if I don't wait 10 seconds, or don't completely switch the ignition off there will be no spark.. so just a plain old HEI would do the trick for me and I'm hoping to fine one locally.
I installed the new radiator and thermostat, ofcourse the thermostat bolts snapped so I had a hell of a time getting them out, but installed threaded rod instead so now if anyone needs to remove the thermostat housing its just two nuts that won't be jammed like the bolts in the aluminum, the car now runs much cooler and never overheats, I have a new heater core aswell but haven't gotten around to replacing it, this car won't be used much in the cold anyway.
thats all for now I think, next up is figuring out the ignition and probably getting around to the dreadful door work... it's inevitable!
