Very jealous of the muscle bar, I want to get one but don't want to pay that much for it
I didn't want to pay that much either!! Hopefully it works well
going to be my first run at using the MSD box on a carbed LS
Fox body 8.8 works but youll need new axles to change bolt pattern. Weld on perched in the right place get dpuble adj uppers atleast both would be best. And geometry might still be an issue plus you still have c clips. Alot on here about 8.8s. You have to change u joints at the drive shaft. Seems like mixed reviews. If its in the budget i think quick performance 9" is around 2k. Or call the guys at southside machine. They make kits for the explorer 8.8. Im undecided myself. Im interested to see which way you go.So weekend update.. had no steam on Saturday, got to working a little bit on the car today. Spent hours scraping off old undercoating and grime, still not done.
Got some parts in.. paint, driveshaft and brake booster, lines etc...
Trying to decide on the best route for a bolt in rear end... I am going to be running the UMI upper/lower control arms in the rear with ride tech coil overs. Would the 8.8 fox body work? or best to go quicktime/strange 9'' ?
