1987 Olds 5.3L LS turbo swap
Like your bracket. I'm in the design process of something similar except we are going to be installing a T6 S475 (a might bit bigger). We've had tons of issues trying to support a T4 on the manifold alone, so we're sure the T6 is going to need some type of support. One thing that is REALLY noce about a G-body is there is tons of room to get the turbo mounted. I see you're running true headers, I have to say that we decided to run truck manifolds just for the reliability due to the heat absorbing/dissipating factor of cast manifolds. I've seen plenty of builds that are using the headers you have, but most of them aren't daily driven which generates plenty of underhood heat issues. I'm sure your headers will work, but might be a pain keeping the plug wires from melting, but definitely can be dealt with.
Are you planning to run flex joints between the headers and the merge?
Is that 7875 from VS racing?
What EMS are you using?
I seen your HP goal initially, 4-500, I think your going to hit that between 8-10psi and then you'll be headed right on by that with a different wastegate spring lol.
Welding looks nice. Keep up the good work.
Thanks man. I have already been I'm the works for heat protection for the spark plugs, I was looking at using dei boots and if that doesn't work I will relocate the coils to the side of the block.
I do plan on using a flex joint between my merge and the turbo since it's mounted to the chassis and my engine doesn't have solid mounts yet I'm going to take my chances and do that because make something work directly mounting to the engine was almost impossible with stock accessories.
It's the vsr 7875 billet t4 .96a/r
And for boost control I'm planning on getting the aem tru boost controller. Also I'm using a stock truck ecu and harness that I converted to a stand alone system. And yes initially my power goals were 4 to 500 lol, but this will surpass that quite a bit I think lol.
Wow, looks like your quickly getting a handle on that new tig metal mender! Welds look great, can't wait to see and hear that thing under boost!
Thanks lol. The stainless is by far the most finicky materiAL that I have worked with using the tig. The heat has to be just right to get the nice blue and gold colors which indicates that it's correct for that thickness, etc.. a lot of people say aluminum is the most difficult to weld but I belive it's a lot more fun lol
Lol thanks I thought it was time for a new one. And it is pretty isn't it lol.
Lol, prolly sitting on a counter so you can pet it when you walk by right lol just kiddin man! I love new parts, like xmas year around when building a car!
I remember when i got my stealth ram efi intake....i think it sat on my bedroom floor for a couple weeks so i could see the vision everytime i walked by it lol!
Reactions: Trezzy98
One day i will boost my 87 cutlass, my fuel system is already setup for boost, just not financially practical right now since i need to redo my interior and motor after paint. But its always in the back of my mind since i need a new engine anyway to go ahead and procharge the beast.
I absolutely love the sound of turbos spooling, but a procharged old school small block sounds bada$$ too!
Reactions: Trezzy98
Lol I opened it the day it arrived and took it straight to my shop I was waiting for it lol.
Reactions: Injectedcutty
