Re: 1987 Olds Pro-touring project build *LONG*
Great looking blast cabinet, Andrew.. Nice job. Your valve covers look cool as well.
FE3X CLONE said:Also bought a used Chevy serpentine setup off Ebay. Turns out it's apparently pretty easy to adapt to an Olds engine using some 1/4" spacers/adapters. Found a guy who has done this with his 455 on Realoldspower:
In the process now of bead blasting the brackets and powder coating.
redboy504 said:Did you make your adapter plates yet? Do you have a template or something? I picked up all the brackets and pulleys this weekend. I just have to order the water pump.Then I can start my mock-up.
FE3X CLONE said:
redboy504 said:Looking good. I have everything but the crank pulley and the water pump. Mostly because I dont know what car to get the ford pulley from.
I just havent decided if I'm going with a polished water pump or not. Do I use the chevy power steering pump too?Keep it up.
3XBrownCutty said:FE3X CLONE said:
Copper pipe 4 corner cooling?
