Figured i would start a build thread to show progress for what I’m building. Bought a 88 cutlass supreme classic someone already did a BBO 455 swap in. Motor was knocking and had a blown head gasket. Pulled her apart, had the engine rebuilt. Went through the trans (turbo 350) fresh seals and gaskets and a coat of paint. Car was a bench seat column shift car so i picked up another 88 parts car that was buckets and console shift and started the interior work while waiting on the engine. Car now has grey buckets with a console. Modified the console to fit a b&m quicksilver shifter. I picked up a set of electronic gauges from New Vintage USA but have not installed them yet. Got the engine back and instead of the stock rebuild I’ve torn it back apart and put a bigger cam, higher compression pistons and a set of rebuilt E big block heads. (Had j’s on it before) next step is going to be trading the turbo 350 for a 200-4r and then I’m planning on upgrading the rear end to a quick performance 9”. i've done the jeep steering shaft upgrade and put a floor shift column in it. also picked up a 3 row aluminum radiator with dual electric fans Here are some of the pictures of the progress along the way. Shes not pretty but she’s mine and i can say I’ve built everything i could myself. Still need to swap the new front nose header over due to mine being busted but ill wait till the engine is in for that. Still have to install the new brake lines, rebuild the front suspension and do the wiring from the gauges to the engine compartment but she's slowly coming along! my goal in the next week is to reassemble the engine with the new parts and get it painted in the correct Olds blue instead of the standard GM Blue that my first engine builder painted it. then if i get froggy, start on the suspension and powerstop brake upgrade. I eventually want to get a set of the GNX black snowflake wheels and a 2" cowl steel hood. but that will come as budget allows.
