hey everyone,
So new to this forum thing, don’t think I’ve ever posted on one in my life so bare with me. As the title says I’m looking to swap my TBI LO5 from my roadmaster into my 84 Grand Prix and convert it to a carb setup.
Now I have read a bunch of these forums and done a whole lot of research and I’m fairly certain I have most the issues worked out. My problem is i work overseas. I will be home for 16 days and would love to drive this with the swap complete so I’m setting my goal as done in 2 probably very long days.
A lot of these question may seem simple but I haven’t even seen the Grand Prix yet and haven’t seen my roadmaster in about 2 years so little fuzzy.
I’ll list what I know and have figured out along with any questions. Any help would be greatly appreciated.
First off not planning on getting too crazy yet. The SBC with just get a cam, intake, carb and probably headers. Easy enough and TBI gone. Also Stick with a Qjet.
- Keeping the Trans that’s in it for now as it’s less headache. Most likely a TH200 but either way same bolt pattern. So need the BOP to SBC adapter plate. Torque converter and flex plate should be fine.
- Engine / frame mounts. I assume my roadmaster engine mounts should be fine, just need a new frame mount from a
g-body that had a SB correct?
- New rad from any g-body that had the V8 from 78-87. Probably order new.
- Fan shroud. Again any G-body same years will work. Even the V6 one will do the trick for now until I have more time.
- Fuel line. Relocated from drivers side to passenger. Probably best to run new line from tank to pump?
- Trans cooler lines (to rad). Should be fine may just require some gentle adjustments.
- vacuum lines. I know there is one from the Trans to hook up, any others to mention?
- Carb linkage. Basically just make sure I get the right kit for the correct style.
- new coolant hoses. Try to find form fit, if not universal flex for now.
That’s basically what I have figured out so far. Hoping all the other accessories such as alternator and such will work without any modification.
My plan is to have all the parts waiting for me so once I’m home I can get to it. Remember it doesn’t have to be pretty as long as it’s safe enough to drive and works.
Don’t wanna be stuck in my other half’s 2002 Taurus. Not really my style lol.
Thanks for any help. If people have part numbers for anything that would be awesome.
