2001 olds alero 3.4 project
axisg
2,686
2,355
YYZ
Re: 2001 olds alero 3.4 project (need help)
I think your car will have the 4t40 trans. One of the common problems is the Pressure Switch in the trans and it produces the problems you are having. Unfortunately its a weak design and leads to transmission failure if left unchecked ( just like the 4t65e in wifeys impala ).
Need to get it hooked up to a proper scanner which will pull transmission codes
FE3X CLONE
2,714
47
48
Ohio
The Auto-lock shouldn't come into play until you put the vehicle in drive. Just letting it idle with the doors closed shouldn't be any big deal.
I had a '98 Intrigue and it was setup this way.
Now on my 2008 GMC Sierra you can go into the driver's information screen and set the autolock to however you would like it to react.
dream on mcss
617
2
Oxford, MI
sh*t how hard would it be to change the pressure sensor? I heard its under the trans pan.
And FE3X CLONE the car was in drive. The trans wouldnt leak in park.
FE3X CLONE
2,714
47
48
Ohio
Right, and I understand why it happened to you. Good reason to get in the habit whenever working under the hood of ANY car to leave the driver's side window down. ;)
I was commenting on fraido2002's post where he said he started his car up to let it warm up. If it wasn't in drive it should have never locked the doors. I used to do the same thing in my Intrigue all of the time.
dream on mcss
617
2
Oxford, MI
hey guys got good news. ive been driving it for the past couple days and the trans problem has sorta smoothed out. it still does it sometimes but all you have to do is let off the gas for a sec then get back on it, and she'll smooth out. i think i should update my list now:
-fix trans leak DONE!
-fix cv joint boot
-fix strut rattle
-oil change
-rotate, balance and align tires
-figure out idiot lights DONE! (need new hub)
-fix passenger door
-and finally do some obnoxious fwd drifts yo
dream on mcss
617
2
Oxford, MI
so i havent really had much time to work on the car, but ive been thinking about what i should do about the cv joint. i asked my auto teacher about it and he said its toast, but me and my moms bf were thinking it would be fine if we just took it off and cleaned it, since the grease in there isnt too dirty. what do you guys think? the new halfshaft would be about a hundo.
Kwik_Cutty88
1,173
662
Coastal North Carolina
I would try to clean it take it for a whip around the block and see how it does.
MrLightning
281
16
northeast,Ohio
i might give it a go as a temporary measure of getting by til you replace it, but typically when they are bad, they are bad!
axisg
2,686
2,355
YYZ
IMO if the hundred bux is too much for the picketbook then grab one from the wreckers as a spare ( should only be $20 or so ). The one in there is going to growl and clunk until it lets go but shouldn't really hurt anything else in the process.
