Looks like a trans out of a 83-84 olds b or d body with a 307... If im wrong somedbody correct me. :lol: I replaced the th350 of my car with one out of a 84 olds delta 88 before my current czf code 2004r. I beat the snot out of it and it wouldn't die but it was behind the old 305. I would have reused it but the input pump shaft splines were really thin. A common problem unless you get a hardened input shaft.If your going to swap it make sure you get a g-body crossmember or a aftermarket one. The dust shields are different for chevy and olds 2004r transmissions. As for the two wires i think you could wire a on/off switch to activate the lock-up converter. I used a B&M kit that uses manifold vacuum to accomplish the same task. I would keep my out for a performance one and have a good base for a rebuild. I have bought two 87 SS ones for $150 each. One was bad so i found another and it had a shift kit installed already. Not too excited about either though. So now im just going to bite the bullet and get one built right. I found a shop that would do it with some upgrades for $600. There is a guy selling a fully rebuilt one with 29k for $350 but don't know what mods if any were done.
Good luck and keep us posted on what you do
