When I first got my car it drove just fine but after driving it for a while the transmission is starting to act up. It doesnt seem to slip or anything but it seems to shift from 1st to 3rd at times and then if your just cruising around town and slow down to take a corner it will not downshift so when you come out of the corner you bog down and the only way to get it to downshift is put your foot on the brake and it downshifts to the gear it should be in. Ive messed with the Tv cable and adjusted it but it does not seem to help. Any advice would be helpful. I have a build turbo 350 with a B&M shift kit and a 3500 stall converter that I thought about installing but was not sure if it would be worth it. I have the stock 305 in it right now if that makes a difference.
