It made the car lighter. 😉
he kept is even lighter , it's not a wide body... 😉
Is that around Indiana or heading towards Johnstown?
Had to be worth a tenth and a kmph!It made the car lighter. 😉
Does the car "feel" heavy?
Thats the biggest complaint I've heard. I assume they handle well enough you don't feel the weight like you would have in an equal weight car from the 80's.
Wont those hood pin.... uhm.... cables.... mess up the paint?!
-Gonz
Gear Ratio | 1st | 2nd | 3rd | 4th | 5th | 6th | Reverse |
2.26 | 1.58 | 1.19 | 1.00 | 0.76 | 0.63 | 2.90 |
I was interested in what transmission you have. I think this is what you have, I like how it is put together and the gearing in it ..... 🙂
TREMEC TR-6060 6-speed manual transmission features at a glance:
- Triple supported output shaft and countershaft
- Taper bearings and cylinndrical roller bearings
- All speed gears supported by needle bearings
- Two-piece gears with laser welded clutch teeth rings
- Advanced and asymmetric clutch teeth in second and third gears improves shifing action
- Hybrid and sintered bronze double and triple cone synchronizers offer lightning quick gear changes with fluid-like engagement
Gear Ratio 1st 2nd 3rd 4th 5th 6th Reverse 2.26 1.58 1.19 1.00 0.76 0.63 2.90
