An OD with a 2.73 rear gear, even with 14" tires, will make OD almost non-useable. What size tires are you running?
If you can handle the swap, a couple of things to keep in mind. If you go higher numerically than 3.08, then you will need to change the center section as well because the the 3.08 and lower are considered a 2 series and higher is a 3 series. The gears are spaced differently depending on the series. There is a spacer that can be bought, but it's a bit too Rube Goldberg for me. From there you have to determine if you want a posi - most everyone does, but I'm confident you 2.73 is a peg leg. If you can live without a posi, then the price just got cut in half. Used open 3 series diffs are borderline free. From there your into a $150 for gears and $100 for a bearing kit if you can do the work yourself. If you can't you ought to expect $300-500 for a shop to complete it for you.
I understand that there isn't alot of love for a 7.5, but if they are put together correctly then they will withstand 300-350HP easily for many years.
