85 cutlass
3.8 w/dualjet
94k miles
no check engine light
9k miles ago:
rebuilt carb
plugs, wires, cap, rotor
intake gaskets
hey all, so i have only put about 9k miles on this gutlass turd since i have owned it. daily driver in the winter and gets occasional use in the summer. currently im doing about 500 miles a week and the car really doesnt sit any length of time.
i have had this part throttle (high load) hitch since i got the car on the road. 9/10 it happens as you pulling a hill and you dip into the throttle... almost like the point (i assume) at which the computer is telling the needles to stay up for heavy load fueling. but im not 100 percent sure. i dont have my dwell meter or most of my tools available at the moment. best way to describe it is it feels like a single smooth hitch as apposed to a rich missfire thats ragged and predictable. or an ignition missfire that happens over and over. engine sound cuts out when it happens so i dont think its the torque converter slipping... btw only does it when the TC is locked.
i turned the needle adjustment 1/2 turn rich from "base" and my hitch got a lot better, but cruising the interstates i can make a "Rich burble" as i apply throttle at say 70mph. if i go 1/2 turn lean from "Base" car lacks power and almost feels like hitch happens more frequently... but the lack of power is more prominent. i feel like its ignition related due to how "precise" this condition is but im thinking i need to start with accell pump and possibly test tps sensor. my concern is i wont find anything simply because i have had the carb apart for various reasons many times and nothing was ever found, nor was my hitch condition ever changed. im asking you guys for maybe a more narrow field at which to look. i also no longer have access to an obd1 reader.
btw, my old work commute was 7 miles long and consisted of one hill that was incredibly long that you would be doing 35-40 at the base. maybe once a week i would get a hitch, no big deal really. now my commute is 60 miles a day with various hills in which i can duplicate concern if i try.
3.8 w/dualjet
94k miles
9k miles ago:
rebuilt carb
intake gaskets
