305s at least respond to mods unlike 231s. 305s also had decent aftermarket support in the past while na 231s never did. Sadly 231s are pretty much stuck at below 130 hp without going deep into the engine or putting a turbo on it. The 3 biggest problems with 231s are the low compression ratio, the poor flowing heads (which Buick solved with turbos as a bandaid), and being 90 degree V6s. On a V6, the banks should be 60 degrees.
