305 to 350 swap!
Does your car have an overdrive?
Not to sure actually, ive never owned an automatic so idk how to tell other than while driving on the highway it doesnt sit at overly high rpms
Look at the shift indicator in the car. Does it just have a "D" or does it have a "D" and then beside it a "D" inside of an "O"?
No overdrive.
It will require a visual to identify which trans you currently have. Are you wanting overdrive?
I would swap it to a 200-4R in that case. One from a factory performance application like a 442 or a GN would be preffered. The mundane 200-4R's have lower shift speeds and softer shift firmness. If your 350 is stout you will want a built trans.
