2fit661ca said:I am about to drop my 307 in my 86 cutlass and I don't know where to put my motor mount on the frame. The motor came out of an 87 Cadillac Brougham, so it uses the chevy motor mounts instead of the olds, and since i don't have the clamshell mounts for the olds motor, I decided to keep the chevy mounts. Where do I place the chevy mounts on the frame? Is there only one place where they will fit?
You should have left the 307 mounts on the frame, and gone down to your local parts store and bought new rubber motor mounts for the block side...
If they're still in place, I recommend going that route. Mostly because the frame side for the 307 is a permanent mount, not the kind that needs eventual replacement like the Chevy. They're kind of a b*tch, so that's why I'd rather leave it.
If you insist on running the Chevy mounts, they go here...
