Yes, the jetting is in the carb. It could be too lean. Maybe as simple as turning out the mixture screws. Start at 2.5-3 turns out. Bigger number jet or smaller primary rods will richen the mixture. Once the choke comes off, it could be so lean to kill the motor. Make sure the base timing is around 20 at idle. I have seen as low as 13 at 1100 on the sticker, didn't run the greatest.
