lildhix said:
dogshit said:
Burnhard hit it on the head. You had the cart ahead of the horse nobody can answer that well without knowing your goals for the car. In your pics you list your engine picture as a ho (olds) 307 but the picture looks like it is a chevy 305 as there is no oil fill tube up front. You are going to want a motor and a transmission because now is the time to do it to save time and labor and the 200 is a weak pos that will most likely only live a short time behind anything much stronger than stock. Guessing on the experience level based on what you have said so far I would say a crate engine with a warranty is a good idea. How good is your credit are you working can you finance a motor if you have to or do you have some money saved up to work with?
on that note. its go be a b
tch to find a combo thats not 10,000
for what its worth,
I found a sbo 350 with a th400 for 350.00... had it rebuilt.. new bearings, rings, camshaft, lifters, harmonic balancer, oil pump, timing chain, heads reworked, crank turned....for less than 1200.00. added a few more goodies that i wanted, but didnt need...put the costs up to about 2g's. But, instead of having a remanufuctard weak v-6 or 30(fill in the number), ive got a nice sounding, torque welding, tire shredding ROCKET!!!...ok...ill shut up....
Seriously...If I were you, Id find a 1969-1973 Olds 350 or any older SBC 350 and rebuild it, you wont be sorry. And, an Olds will fit almost exactly like the 307 did, so id try to find one of those first....Just my two cents and good luck!
