dogshit said:Burnhard hit it on the head. You had the cart ahead of the horse nobody can answer that well without knowing your goals for the car. In your pics you list your engine picture as a ho (olds) 307 but the picture looks like it is a chevy 305 as there is no oil fill tube up front. You are going to want a motor and a transmission because now is the time to do it to save time and labor and the 200 is a weak pos that will most likely only live a short time behind anything much stronger than stock. Guessing on the experience level based on what you have said so far I would say a crate engine with a warranty is a good idea. How good is your credit are you working can you finance a motor if you have to or do you have some money saved up to work with?
Blueprint, really? I went that route once.GhettoRacingKid said:i agree with pulling a motor.
if you are going new. get something better. blueprint motors that sells threw jegs and summit has some 400+ ho motors pretty cheap.
daily driverBurnhard said:The 200 trans will not stand up behind any kind of hp or TQ upgrade.The small block olds is a great engine and makes good hp and tq.Before you buy an engine you have to know what your goals are for this car.Is this your daily driver,weekend car,street strip car,show car. You can not spend to much time on planing, a good plan will save you time and money.
Good luck with your build
whats wrong with themcullencombs said:Blueprint, really? I went that route once.GhettoRacingKid said:i agree with pulling a motor.
if you are going new. get something better. blueprint motors that sells threw jegs and summit has some 400+ ho motors pretty cheap.![]()
on that note. its go be a bdogshit said:Burnhard hit it on the head. You had the cart ahead of the horse nobody can answer that well without knowing your goals for the car. In your pics you list your engine picture as a ho (olds) 307 but the picture looks like it is a chevy 305 as there is no oil fill tube up front. You are going to want a motor and a transmission because now is the time to do it to save time and labor and the 200 is a weak pos that will most likely only live a short time behind anything much stronger than stock. Guessing on the experience level based on what you have said so far I would say a crate engine with a warranty is a good idea. How good is your credit are you working can you finance a motor if you have to or do you have some money saved up to work with?
for what its worth,lildhix said:on that note. its go be a bdogshit said:Burnhard hit it on the head. You had the cart ahead of the horse nobody can answer that well without knowing your goals for the car. In your pics you list your engine picture as a ho (olds) 307 but the picture looks like it is a chevy 305 as there is no oil fill tube up front. You are going to want a motor and a transmission because now is the time to do it to save time and labor and the 200 is a weak pos that will most likely only live a short time behind anything much stronger than stock. Guessing on the experience level based on what you have said so far I would say a crate engine with a warranty is a good idea. How good is your credit are you working can you finance a motor if you have to or do you have some money saved up to work with?tch to find a combo thats not 10,000
