I had bought a complete TPI setup complete with wiring and ECU off E-bay a few months prior to buying the Vette motor/transmission. It was an aftermarket setup from Affordable Fuel Injection in Michigan. It was stripped of all uneccessary wiring and runs on the basics. No EGR or knock sensor, just temp, TPS, etc. It was also setup for A/C and automatic trans. If you visit their website I think their harnesses are available separate, with or without ECU. Mine also has their performance tuning I think, because I had a 1990 Vette a few years ago and it didn't have the smoke that this thing does.
How much can you pick up the eng/transmission with wiring for, if you don't mind? I could have had the wiring and computor with my motor for another $100. I paid $1800 for the rest, it was complete with acccessories, starter, everything but the wiring and ECU. I stripped off the smog junk and gutted the smog pump. So it doesn't do anything but hold the belt now.
I ran the computor harness out the right side of the cowl, the same as factory. The harness on the left only has a handful of wires going to the engine, i.e. tach signal, ignition power, and I think the oil light is in there. For the left side I found another harness to chop up only so I could keep my original intact in the event the car ever goes back to stock.
I kept the battery on the left side and used the original power lead to the starter off the 307 since it is about a mile long. I also made my own transmission cooler lines and just ran an aftermarket cooler up front since the cooler lines out of the transmission were bigger for the Vette than my 200R4's were. I also had to have the driveshaft shortened.
I need to get on the ball with pics. I lost he originals that I took as I went, so there aren't any of the motor in the car without the nose on.
I don't mind the questions.
